Managing Communication
Communication should be a critical consideration when defining the vision for a digital workforce. Developing a communication strategy at an early stage for delivering information to your target audience is highly recommended. It is essential to ensure that the vision is articulated consistently and widely across the organization.
To achieve this, the following steps may be considered:
Define your objectives
Define your overall communication objectives. What are the results that you want to achieve? You may look to create communication objectives which are SMART (Specific, Measurable, Achievable, Realistic, Time-focused).
Define your key audiences
It is important to identify the audience and why they need to be aware of the messages that you are delivering.
Identify Media Channels
Plan to deliver your messages to your key recipients through multiple media channels. Decide which media channels would be the most effective to get your message delivered to your target audiences.
Create a Communication Plan
Create a communication plan to define and time your steps for the best results. Based on your research and your resources, develop a solid timing strategy to execute the steps of your communication plan.
Evaluate the results of Communication
It is important to frequently measure the results of communications and understand whether the communications objectives are achieved.  In case the objectives are not achieved, it is highly recommended to revisit any of the previous steps and make improvements.
For a more detailed exploration of driving cultural adoption through communication visit our Business Integration page.
Business Integration: Driving cultural adoption of RPA
Success Accelerator
Blue Prism’s Success Accelerator program combines various levels of mentorship and access to our Expert Services, Technology Ecosystem and Certified Partners based on the size and maturity of your digital workforce operations.
